J-turn Steering
The J-turn event (or Fishhook maneuver) simulates a vehicle's dynamic response to a sudden, sharp steering input in one direction, followed by a brief pause (dwell time) to let the vehicle to react, and then an equally sharp steering input in the opposite direction.
The event is used to characterize the stability of vehicles. Both steer directions can be run by reversing the sign of the steering inputs. The Altair Driver is used to maintain a constant speed.
The J-turn event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries. Automated output reports are available to plot the results.
The J-Turn event follows the ISO +7401-2003 - Road Vehicles-Lateral transient response test methods-Open-loop test methods. It is also designed to simulate the NHTSA fishhook test as described in DOT publication DOT HS 809 705, “Phase VIII of NHTSA’s Light Vehicle Rollover Research Program-A Demonstration of the Dynamic Tests Developed for NHTSA’s NCAP Rollover Rating System”.
Figure 1. J-turn event
Parameter Name Description
Units Describes the Length, Velocity, and Acceleration units.
  • Length (Model, m, ft)
  • Velocity (Model, m/s, km/h, mph).
  • Acceleration (Model, m/s2, g’s).
Velocity Initial vehicle velocity.
Initial power run The time period at the start of the event used to ensure the vehicle reached the steady-state condition before the steering input begins.
First turn direction Defines the steer direction used in the first turn.
First steer angle* Angle in degrees of the initial steer input. A positive number turns the vehicle right and a negative number turns the vehicle left (as seen by the driver).
First lean angle** The demand lean angle for the initial turn in degrees.
First step duration Time required to apply the First steer angle to the steering wheel (the angle is applied using a step function).
First turn duration Time duration for which the steering input remains fixed at the specified First steer angle.
Second turn direction Defines the direction used in the second turn.
Second steer angle* Steering angle in degrees of the second steer input.
Second lean angle** The demand lean angle for the second turn in degrees.
Second step duration The time required to apply the Second steer angle to the steering wheel (the angle is applied using a step function).
Second turn duration Time duration for which steering input remains fixed at the specified Second steer angle.
*Applicable only for Cars/Trucks (that is, Non-leaning events).
**Applicable only for Two-wheeler (that is, Leaning events).
Initial Static and Steering Ratio
Run initial static Enables the execution of the initial static simulation.
Compute steering ratio Enables the automatic calculation of the steering ratio at the beginning of the event simulation. Turn this option off to use a different Steering ratio (default value of 16 is provided).
End Time Calculation
The parameters defined above are also used to determine the total simulation time. The simulation time is specified in the Altair Drive File (.adf), as shown below:
Figure 2. Maneuvers List Block for a J-Turn Steering Event
For more information see the Altair Driver File Blocks topic.
The simulation time is calculated using the following equation:
Maneuver Simulation Time Equation
Maneuver 1 Initial power run+First step duration+First turn duration+Second step duration+Second turn duration
Controller Settings
Non-leaning events (Cars/Trucks)
LONGITUDINAL – TRACTION CONTROLLER SETTINGS
  • Use additional control: Enables the additional feedback control for the traction control. The gains for the controller can be edited by toggling this check box.
    Kp Proportional gain for the feedback PID controller
    Ki Integral gain for the feedback PID controller
    Kd Derivative gain for the feedback PID controller
LATERAL – STEERING CONTROLLER SETTINGS
  • Altair Driver uses Feedforward steering controller for non-leaning vehicles like Cars and Trucks. The following settings can be edited by the user.
    Look ahead time Look ahead time for the feedforward model to evaluate future states of the vehicle
    Prediction step size Maximum step size, used by the Driver feedforward steering model
For more information see the Altair Driver Mathematical Methods topic.
Leaning events (Two-wheelers)
  • The Lean PID and Lateral Error PID controllers only apply to leaning vehicles (for example, motorcycles and scooters).
    Steer control: Control mode for steering can be switched between ‘MOTION’ and ‘TORQUE’. When set to ‘MOTION’, the steering input is defined by the steering wheel angle. When set to ‘TORQUE’, the steering is controlled via the applied torque on the steering wheel.
    Lean control
    The Lean PID takes as input a demand lean angle and outputs front fork (steering) angle. For open loop events the lean angle demand is a function of time. For closed loop path following events the demand lean angle is computed based on the vehicle speed and the path curvature with a correction for lateral path error.
    Kp Proportional gain for the lean controller
    Ki Integral gain for the lean controller
    Kd Derivative gain for the lean controller
    Lateral error control
    The Lateral Error PID takes as input the predicted lateral path error and outputs an increment to the demanded lean angle. The lateral error is computed by predicting the vehicle’s lateral position relative to the path by the look ahead time in the future. The Lateral Error PID acts to lean the vehicle toward the path.
    Kp Proportional gain for the lateral error controller
    Ki Integral gain for the lateral error controller
    Kd Derivative gain for the lateral error controller
    For more information see the Leaning Two and Three Wheeler Vehicles and Gain Tuning for Leaning Two and Three Wheeler Vehicles topics.
Note: Since the J-Turn Steering event uses an open-loop steering input, no steering controller is required for non-leaning vehicles. However, for leaning vehicles, a lean controller is required to follow the demand lean angles.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
Three options are available to specify the road in the event, Flat Event, Road File, and Tires.
Flat Event
Uses a flat smooth road for the event with no required road file.
When the Flat Event is selected, the Graphics Setting option is available with the following parameters:
  • View path centerline: Enables the visualization of the event path.
    • This check box is disabled for open loop events without a path.
  • View grid graphics: Enables the visualization of the road grid graphics.
    • When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
    Grid length Defines the length of the road. Enter a positive value in the model units.
    Grid Width Defines the width of the road. Enter a positive value in the model units.
    Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units.
    Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
Road File
The road file option enables the selection of a road file to be used in the event. Using this option, all tires in the model consider the event specified road file instead of the file included in the tire entities.
Tires
Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Simulation Settings
Analysis Parameters
Define the numerical and output settings for the simulation:
Print interval The time step between successive outputs of simulation results.
Real-Time Empowered When enabled, MotionSolve builds the FMU of the vehicle and solves it in real-time.
Code generation When enabled, the C code for the MotionSolve Vehicle model excluding the driver and tire will be generated. This code can be used to compile and build an FMU, which can be used with any FMU compatible software.
For more information see the Parameters: Simulation - Attributes topic.
Dynamic Settings
Defines the simulation control parameters for a time-domain-based nonlinear dynamic analysis. For more information see the Parameters: Transient Solver - Attributes topic.
Static Settings
Defines the solution control parameters for static and quasi-static analysis. For more information see the Parameters: Static Solver - Attributes topic.
Automated Output Report
The list of outputs present in J-Turn Steering event report are as follows:
Report Name Report Signals
Steering Wheel Angle, Lateral Acceleration, Vehicle Velocity and Yaw Rate
  • Steering Wheel Angle vs. Time
  • Lateral Acceleration vs. Time
  • Longitudinal Velocity vs. Time
  • Yaw Rate vs. Time
Vehicle CG Displacement
  • Vehicle CG Disp(Y) vs. Vehicle CG Disp(X)
Roll Angle and Side Slip Angles
  • Roll Angle vs. Time
  • CG Sideslip Angle vs. Time
  • Front Sideslip Angle vs. Time
  • Rear Sideslip Angle vs. Time
Vertical Tire Forces
  • Left Front Tire Vertical Force vs. Time
  • Right Front Tire Vertical Force vs. Time
  • Left Rear Tire Vertical Force vs. Time
  • Right Rear Tire Vertical Force vs. Time
Lateral Tire Forces
  • Left Front Tire Lateral Force vs. Time
  • Right Front Tire Lateral Force vs. Time
  • Left Rear Tire Lateral Force vs. Time
  • Right Rear Tire Lateral Force vs. Time
Tire Lateral Slip
  • Left Front Tire Lateral Slip vs. Time
  • Right Front Tire Lateral Slip vs. Time
  • Left Rear Tire Lateral Slip vs. Time
  • Right Rear Tire Lateral Slip vs. Time
Longitudinal Tire Forces
  • Left Front Tire Longitudinal Force vs. Time
  • Right Front Tire Longitudinal Force vs. Time
  • Left Rear Tire Longitudinal Force vs. Time
  • Right Rear Tire Longitudinal Force vs. Time
Tire Longitudinal Slip
  • Left Front Tire Longitudinal Slip vs. Time
  • Right Front Tire Longitudinal Slip vs. Time
  • Left Rear Tire Longitudinal Slip vs. Time
  • Right Rear Tire Longitudinal Slip vs. Time
