Constant Radius
A Constant radius event simulates a vehicle driving in a circular path, typically with increasing speed. The event predicts the vehicles roll and understeer characteristics with increasing lateral acceleration.
The event maintains a constant turn radius and varies the vehicle velocity to produce increasing amounts of lateral acceleration. Steering and torque controllers maintain the path and the speed of the vehicle through the event.
The constant radius event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries. Automated output reports are available to plot the results.
The constant radius event follows the ISO +4138-2004 - Passenger cars — Steady-state circular driving behavior — Open-loop test methods.
Figure 1. Constant Radius Event
Parameter Name Description
Units Describes the Length, Velocity, and Acceleration units.
  • Length (Model, m, ft)
  • Velocity (Model, m/s, km/h, mph).
  • Acceleration (Model, m/s2, g’s).
Radius Radius of the circle that the vehicle CG follows during the constant radius portion of the event.
Initial straight Straight distance section of the event before the constant radius portion.
Initial velocity Initial vehicle velocity.
Final velocity Final vehicle velocity desired in the simulation.
Initial lateral acceleration Estimated initial lateral acceleration. This value is not editable and is calculated using the initial speed and the radius parameters.
Final lateral acceleration Estimated final lateral acceleration. This value is not editable and is calculated using the initial speed and the radius parameters.
Turn direction Direction the vehicle turns during the event (as seen by the driver).
Transient time Time duration for which vehicle accelerates/decelerates after achieving steady state.
Initial Static and Steering Ratio
Run initial static Enables the execution of the initial static simulation.
Compute steering ratio Enables the automatic calculation of the steering ratio at the beginning of the event simulation. Turn this option off to use a different Steering ratio (default value of 16 is provided).
End Time Calculation
The parameters defined above are also used to determine the total simulation time. The maximum simulation time for each maneuver is specified in the Altair Drive File (.adf), as shown below:
Figure 2. Maneuvers List Block for a Constant Radius Event
In a Constant Radius event:
  • MANEUVER_1 represents the initial straight-line section.
  • MANEUVER_2 corresponds to the constant-radius portion of the event.
The maximum simulation time for each maneuver is calculated using the following equations:
Maneuver Simulation Time Equation
Maneuver 1 (Initial straight+2*Radius*Entry Angle)/Initial Velocity+5
Maneuver 2 Transient time
The actual simulation time is defined by the end conditions specified in each maneuver:
Figure 3. Maneuver Blocks for a Constant Radius Event
  • MANEUVER_1 terminates when is true for 0.1 seconds continuously.
  • MANEUVER_2 terminates when is true for 0.001 seconds continuously.
For more information see the Altair Driver File Blocks topic.
The total simulation time corresponds to the sum of the actual simulation times for Maneuver 1 and Maneuver 2.
Controller Settings
Non-leaning events (Cars/Trucks)
LONGITUDINAL – TRACTION CONTROLLER SETTINGS
  • Use additional control: Enables the additional feedback control for the traction control. The gains for the controller can be edited by toggling this check box.
    Kp Proportional gain for the feedback PID controller
    Ki Integral gain for the feedback PID controller
    Kd Derivative gain for the feedback PID controller
LATERAL – STEERING CONTROLLER SETTINGS
  • Altair Driver uses Feedforward steering controller for non-leaning vehicles like Cars and Trucks. The following settings can be edited by the user.
    Look ahead time Look ahead time for the feedforward model to evaluate future states of the vehicle
    Prediction step size Maximum step size, used by the Driver feedforward steering model
For more information see the Altair Driver Mathematical Methods topic.
Leaning events (Two-wheelers)
  • The Lean PID and Lateral Error PID controllers only apply to leaning vehicles (for example, motorcycles and scooters).
    Steer control: Control mode for steering can be switched between ‘MOTION’ and ‘TORQUE’. When set to ‘MOTION’, the steering input is defined by the steering wheel angle. When set to ‘TORQUE’, the steering is controlled via the applied torque on the steering wheel.
    Lean control
    The Lean PID takes as input a demand lean angle and outputs front fork (steering) angle. For open loop events the lean angle demand is a function of time. For closed loop path following events the demand lean angle is computed based on the vehicle speed and the path curvature with a correction for lateral path error.
    Kp Proportional gain for the lean controller
    Ki Integral gain for the lean controller
    Kd Derivative gain for the lean controller
    Lateral error control
    The Lateral Error PID takes as input the predicted lateral path error and outputs an increment to the demanded lean angle. The lateral error is computed by predicting the vehicle’s lateral position relative to the path by the look ahead time in the future. The Lateral Error PID acts to lean the vehicle toward the path.
    Kp Proportional gain for the lateral error controller
    Ki Integral gain for the lateral error controller
    Kd Derivative gain for the lateral error controller
    For more information see the Leaning Two and Three Wheeler Vehicles and Gain Tuning for Leaning Two and Three Wheeler Vehicles topics.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
Three options are available to specify the road in the event, Flat Event, Road File, and Tires.
Flat Event
Uses a flat smooth road for the event with no required road file.
When the Flat Event is selected, the Graphics Setting option is available with the following parameters:
  • View path centerline: Enables the visualization of the event path.
    • This check box is disabled for open loop events without a path.
  • View grid graphics: Enables the visualization of the road grid graphics.
    • When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
    Grid length Defines the length of the road. Enter a positive value in the model units.
    Grid Width Defines the width of the road. Enter a positive value in the model units.
    Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units.
    Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
Road File
The road file option enables the selection of a road file to be used in the event. The road property file used in this option overrides the road property files used in the Tire entities within the model. The road property file should be compatible with the tire property file that is used in the vehicle.
Tires
Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Simulation Settings
Analysis Parameters
Define the numerical and output settings for the simulation:
Print interval The time step between successive outputs of simulation results.
Real-Time Empowered When enabled, MotionSolve builds the FMU of the vehicle and solves it in real-time.
Code generation When enabled, the C code for the MotionSolve Vehicle model excluding the driver and tire will be generated. This code can be used to compile and build an FMU, which can be used with any FMU compatible software.
For more information see the Parameters: Simulation - Attributes topic.
Dynamic Settings
Defines the simulation control parameters for a time-domain-based nonlinear dynamic analysis. For more information see the Parameters: Transient Solver - Attributes topic.
Static Settings
Defines the solution control parameters for static and quasi-static analysis. For more information see the Parameters: Static Solver - Attributes topic.
Automated Output Report
The list of outputs present in a Constant radius change event report are as follows:
Report Name Report Signals
Yaw Rate and Understeer
  • Yaw Rate vs. Lateral Acceleration
  • Understeer vs. Lateral Acceleration
Steering Input and Accelerations
  • Steering Wheel Angle vs. Time
  • Steering Wheel Torque vs. Time
  • Lateral Acceleration vs. Time
  • Drive Torque vs. Time
Vehicle Velocities
  • Yaw Rate vs. Time
  • Longitudinal Velocity vs. Time
  • Lateral Velocity vs. Time
Vehicle Slip Angles
  • Front Sideslip Angle vs. Time
  • Rear Sideslip Angle vs. Time
  • CG Sideslip Angle vs. Time
Roll Angle
  • Roll Angle vs. Time
Steer/Suspension Travel
  • Front Steer Angle vs. Time
  • Rear Steer Angle vs. Time
  • Left Front Suspension Travel vs. Time
  • Right Front Suspension Travel vs. Time
  • Left Rear Suspension Travel vs. Time
  • Right Rear Suspension Travel vs. Time
Steering Angle, Steering Torque, Roll Angle and Vehicle Path
  • Steering Wheel Angle vs. Lateral Acceleration
  • Steering Wheel Torque vs. Lateral Acceleration
  • Roll Angle vs. Lateral Acceleration
  • Vehicle Path
Vehicle Sideslip vs. Acceleration
  • Front Axle Sideslip vs. Lateral Acceleration
  • Rear Axle Sideslip vs. Lateral Acceleration
  • CG Sideslip Angle vs. Lateral Acceleration
Steering Wheel Angle vs. Vehicle Sideslip Angle
  • Steering Wheel Angle vs. Vehicle Sideslip Angle
Vertical Tire Forces
  • Left Front Tire Vertical Force vs. Time
  • Right Front Tire Vertical Force vs. Time
  • Left Rear Tire Vertical Force vs. Time
  • Right Rear Tire Vertical Force vs. Time
Lateral Tire Forces
  • Left Front Tire Lateral Force vs. Time
  • Right Front Tire Lateral Force vs. Time
  • Left Rear Tire Lateral Force vs. Time
  • Right Rear Tire Lateral Force vs. Time
Tire Lateral Slip
  • Left Front Tire Lateral Slip vs. Time
  • Right Front Tire Lateral Slip vs. Time
  • Left Rear Tire Lateral Slip vs. Time
  • Right Rear Tire Lateral Slip vs. Time
Longitudinal Tire Forces
  • Left Front Tire Longitudinal Force vs. Time
  • Right Front Tire Longitudinal Force vs. Time
  • Left Rear Tire Longitudinal Force vs. Time
  • Right Rear Tire Longitudinal Force vs. Time
Wheel Aligning Torques
  • Left Front Tire Aligning Torque vs. Time
  • Right Front Tire Aligning Torque vs. Time
  • Left Rear Tire Aligning Torque vs. Time
  • Right Rear Tire Aligning Torque vs. Time
Vertical Tire Forces vs. Lateral Acceleration
  • Left Front Tire Vertical Force vs. Lateral Acceleration
  • Right Front Tire Vertical Force vs. Lateral Acceleration
  • Left Rear Tire Vertical Force vs. Lateral Acceleration
  • Right Rear Tire Vertical Force vs. Lateral Acceleration
Lateral Load Transfer
  • Front Lateral Load Transfer vs. Lateral Acceleration
  • Rear Lateral Load Transfer vs. Lateral Acceleration
