Force Graphics Options
Note: The offset prevents
the tire, wheel, and chassis graphics from obscuring the force graphics.
Select the Force Graphics check box to turn the graphics on and off.
The Force Graphics controls are explained in the table below:
| Control | Description |
| Force Graphics | Select the Force Graphics box to activate force graphics for viewing in HyperView. Clear the check box to deactivate force graphics. |
| Scale | Enter a real number greater than zero to define the length per unit force of the graphics. For example: At t = 2.0 sec, if the FZ of the contact patch force is 1000 N, a scale of 5 would result in the graphic vector length = 1000 / 5.0 = 200 mm. |
| Radius | Enter a real number greater than zero giving the radius of Force Graphic Arrow. |
| Offset | Enter a real number giving the distance out board (laterally away from the vehicle center-line) of the tire contact patch to display the tire force graphics. |
| Graphics Color | Tire Force Arrows color. The color is used for the FX, FY, and FZ Vectors. |
