2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
Add an FMU to the model or export a model as an FMU.
MotionView and MotionSolve support multiple tire models. The Tire entity can be added to a full vehicle model as a single entity or as a pair.
Reference material for the scripting interface which is a set of Tcl/Tk commands.
