Edit Solution
Analysis > Transient Magnetic Loads > Edit Solution
Introduction
After to Edit the solution, all meshed bodies can be assign to the solution.
The bodies to be assigned to the solution:
  • should be meshed with surface mesh or volume mesh (limitation to be left)
  • should belong to the same .gda model
Note: The 2D Transient Magnetic solution is created before, to have more details about the creation of the 2D Transient Magnetic solution, please refer to Transient Magnetic solution.
Steps
  1. Double click on the Solution in the Solution Browser
  2. Select all the meshed bodies:
    The outlines of all the bodies are displayed in red.
  3. Click on the OK button
    All the bodies are now assigned to the solution.
