Transient Magnetic solution
Solutions > Electromagnetic > Transient Magnetic
Introduction
The Transient Magnetic application allows the study of the phenomena created by a time variable magnetic field. The magnetic field is related to the presence of variable currents (and possibly permanent magnets).This application allows the consideration of induced currents in conducting regions (Eddy currents). It also allows the consideration of skin effects and proximity effects in the conducting regions.
2D 2D with skewed Motor
Note: More information about Skewed Motor option.
3D AxiSymmetric
The Transient Magnetic application can be used for different types of devices. We are principally interested in the study of devices supplied by current of varied shape (echelon, trapezoid…) or by transient phenomena (linked to current variation caused by powering, short circuits…)
The Transient Magnetic application is principally used with Circuit coupling and/or Kinematics coupling for rotating machines, transformers, etc. study in transient state.
Note: For more information about the Transient Magnetic workflow, please consult:
Solution dialog box
  • The transient solution is available for 2D, AxiSymmetric and 3D cases
  • In case of 2D the domain depth must be defined to consider the electromagnetic effects in the third dimension
  • In the case of transient magnetics, the user has a choice to select the driving transient variable or the control parameter. This can be in the general case Time or in the case of rotational motion (in the case of e-motors for example), the transient variable can be defined in terms of Angular position that defines the rotation or in the case of linear motion (for a linear actuator for example), the transient variable can be defined in terms of Linear position that defines the translation.
  • The control parameters (Time or Angular position or Linear position) can be defined by several Control type:
    • By step value
      • Max time
      • Time step
      Example: Max time = 5s, Time step = 1s → The list of step will be 0s - 1s - 2s - 3s - 4s - 5s
    • By step number (linear)
      • Max time
      • Number of steps
      Example: Max time = 10s, Number of steps = 6 → The list of step will be 0s - 2s - 4s - 6s - 8s - 10s
    • By step list: choose a table already existing or create a table by clicking on Create
    • By multi interval: click on Define to open the Define a multi interval scenario dialog
      You have the possibility to define several interval using different Variation type (Step value, step number (linear), step number (logarithmic), step list).
      To create multi intervals:
      • click on "+" symbol
      • choose the variation type
      • enter the corresponding fields (Min, Max and Variation value)
      • click on Preview to see the list of values
      • click on "+" symbol to add another interval
        → The Min value is automatically set by the Max value of the preview interval
      • enter the corresponding fields (Max and Variation value)
      • click on Preview to refresh the list of values
      • Add another interval or click on OK to validate the multi interval
    CAUTION: With the control of the position the Min value must be the same as the initial position set in the Motion LBC.
    Note: The Angular position and Linear position control parameters are not compatible with all Motion types. For more information, please refer to Motion
  • Specifically for the case of e-motors (only in 2D at this time), users can define multi-control to simultaneously calculate multiple working points defined by current, control angle and speed.
Automatic parameter creation
The creation of the transient magnetic solution now automatically creates some parameters that can be used to define multiparametric analysis.
  • Creation of the transient magnetic solution now automatically creates a variable Time
    The creation of this parameter is reflected in the output window.
    This parameter can be used to define transient quantities like current or voltage waveforms eg. I1 = MAX_CURRENT*SIN(OMEGA*Time+Gamma*PI/180).
    Note: The parameter does not reflect the actual values defined in the solution but only default values.
  • Creation of the the motion load named for instance Motion_1 now automatically creates three variable:
    • Angular_Position_Motion_1
    • Angular_Speed_Motion_1
    • ElecMag_Torque_Motion_1
    As for Time parameter, those variables can be used in formula to define quantities.
  • Creation of the multi control solution, by defining multiple working points creates the parameters RMS_Current, Speed and Gamma in addition to the Time parameter
    Note: The parameters do not reflect the actual values defined in the solution but only default values.
Typical examples
  • Typical example of a transient magnetic problem is shown below for a passive conductor which is not circuit linked.
    air or vacuum
    magnetic environment
    (non conducting)
    conducting environment
    (non magnetic) without Eddy current
    conducting environment (magnetic or not) with possible Eddy current
  • Another example where the conductors are linked to an external circuit.
    air or vacuum
    (non conducting)
