AC Supplied Conductors solution
Introduction
AC Supplied Conductors “SCAC” solution allows the computation of parameters including the impact of non-ideal behaviors (parasitic couplings) within complex structures in electrical engineering and power electronics. This solution makes it possible to calculate the distribution of electrical current within the structure and its connected active and passive components, as well as Joule losses distribution, which can be calculated and displayed..
Frequency definition
Different type of frequency definition are possible:
- By step value
By step number (linear)
By step number (logarithmic)
By step list
- By multi interval
Click on Define, and choose different intervals with different type of variation possible.
The list of values is displayed below after to click on Preview
- By single frequency
