Parasitics Extraction solution
Solutions > Electromagnetic > Parasitics Extraction
Introduction
Parasitics Extraction solution is the SimLab solution to model non-ideal behaviours of electrical interconnects and to take them into account in system-level simulations of power electronics converters.
Note: For more information about the Parasitics Extraction workflow , please consult:
Simulation type
Two simulations are possible:
  • S-Parameter computation to compute S-Parameter matrices
  • Impedance computation to compute the Self and Mutual Impedances
Note: The two simulation types can be switched between each other in edit mode when the port type is set to Differential.
Frequency definition
Different type of frequency definition are possible:
  • By step value
  • By step number (linear)
  • By step number (logarithmic)
  • By step list
  • By multi interval
    Click on Define, and choose different intervals with different type of variation possible.
    The list of values is displayed below after to click on Preview
  • By single frequency
Port definition
Port definition
Two types:
  • Single-Ended: only one input face to select for the creation of the port. Its output face is virtually grounded. This type is not compatible with Impedance computation.
  • Differential: input and output face to select for the creation of a port.
