Edit Contacts
Contact properties can be edited using the Entity Editor. Checks on graphics for suitability for contacts can also be performed.
Note: Certain properties can also be edited using a microdialog by selecting the contact and clicking on the Contacts tool in the Model ribbon.
Contact Properties
Property Description
General
Label Descriptive label for the entity.
Varname Variable name of the entity.
ID Integer identifier.
Active Active state of the entity. True or False. Entity is deactivated if False.
Type Contact type. 3D or 2D rigid to rigid or Point to Deformable Surface. Once entity is created, this property is read-only.
3D Contact type is 3D. It offers the following combinations of I type and J type.
I Type Type of contact pair on the I (first) side. Body or Deformable Curve or Deformable surface.
I Body With I Type as Body, select the body reference for the first body in the contact pair.
I Deformable Curve Graphic With I Type as Deformable Curve, select the deformable curve graphic as the first reference in the contact pair.
I Deformable Surface Graphic With I Type as Deformable Surface, select the deformable surface graphic as the first reference in the contact pair.
J Type Type of contact pair on the J (second) side. Body or Deformable Curve or Deformable surface.
J Body With J Type as Body, body reference to the second body in the contact pair.
J Deformable Curve Graphic With J Type as Deformable Curve, select the deformable curve graphic as the second reference in the contact pair.
J Deformable Surface Graphic With J Type as Deformable Surface, select the deformable surface graphic as the second reference in the contact pair.
Graphics Click on Graphics to access the Contact Graphics dialog and select the I and J graphics involved in contacts, as well as set the direction of contact using the Material Inside flag for each graphic. Contact with rigid bodies can have multiple graphics selected. By default, all graphics belonging to the body are selected. See the comments below.
Highlight contact side Display the sides of graphic in contact.
Mesh errors/No mesh errors Mesh error will be active if any of the graphics have open edges or T connections. Click this option to highlight the mesh errors.
2D Rigid To Rigid Contact is between two geometrical curves belonging to different bodies in a 2D plane.
I Body Select the body reference for the first body in the contact pair.
J Body Select the body reference to the second body in the contact pair.
Graphics Click on Graphics to access the Contact Graphics dialog and select the I and J graphics involved in contacts. By default, all Curve graphics belonging to the body are selected. Flip Contact side - see the comments below.
Point to Deformable Surface Contact is between a body represented as a sphere with the selected point as center and a deformable surface.
Origin Select the center point of the representative sphere on the I Body.
Deformable Surface Select the deformable surface for the contact pair.
Properties
Normal Force Define properties for force calculation in the normal direction of the contact.
Type Select the method of normal force calculation.
Impact Use the Impact method for force calculation. Applicable for 3D or 2D rigid to rigid contact.
Stiffness Enter a stiffness value for the boundary surface interaction. (Real, positive)
Exponent Enter a value for the Exponent on penetration depth in the force-penetration depth characteristic of the contact interface.
For a stiffening spring characteristic, it must be greater than 1.0. For a softening spring characteristic, it must be less than 1.0.
Exponent > 0
Damping Enter a value (> 0.0) for the maximum Damping coefficient.
Penetration Depth Enter a value (> 0.0) for the Penetration depth beyond which full damping is applied.
Poisson Use the Poisson method for force calculation. Applicable for all types of contact.
Radius Enter a value for the radius of the representative sphere on the body that the deformable surface will be contacting. (applicable for Point to Deformable surface contact only)
Penalty Enter a value for the Penalty parameter to determine the local stiffness properties between materials. Larger values lead to reduced penetration between two bodies.
Restitution coefficient Enter a value for the Restitution coefficient. This value represents the energy loss between the two contact bodies. The valid range for this value is between 0.0 and 1.0. A value of 1.0 represents no energy loss and perfectly elastic contact. A value of 0.0 represents a perfectly plastic contact and all energy is dissipated during contact.
Normal transition velocity Enter a value of velocity at which full damping is applied. (not applicable for Point to Deformable surface contact)
Volume Model Use the Volume method for force calculation. Applicable for 3D or 2D rigid to rigid contact.
Bulk Modulus Enter the bulk modulus value (> 0.0). The bulk modulus of a substance measures the resistance of a substance to uniform compression. It is defined as the ratio of the infinitesimal pressure increase to the resulting relative decrease of the volume.
Shear Modulus Enter shear modulus value (> 0.0).
The shear modulus or modulus of rigidity is defined as the ratio of shear stress to shear strain.
Layer depth Enter a value for depth of material (>0.0).
Exponent Enter a value for the exponent of the force deformation characteristic (> 0.0).
Damping Enter a value for the damping coefficient (> 0.0).
Linear Use a linear spring-damper model for contact force. Applicable for Point to Deformable surface contact only.
Stiffness Enter a value for the stiffness of the contact force (> 0.0).
Damping Enter a value for the damping of the contact force (> 0.0).
User defined Use a user defined formulation for the normal and friction force calculation. Applicable for all types of contact.
User expr Provide the user expression – USER() call to the subroutine with arguments.
Use local file and function name Optional. Provide a local file and function for the sub-routine.
Local file Select a file for the subroutine based on Function type.
Function type Select the type of file. DLL, Python, MATLAB or Compose.
Function name Name of the function within the subroutine file that needs to be called.
Note: If local file and filename is not used, solver may use the subroutine based on its default search criteria. Refer the solver reference guide to learn more.
Friction Force Define properties for force calculation in the tangential direction of the contact.
Type Select the type of setting for frictional force calculation.
Disabled Friction is disabled.
Dynamic Only Only dynamic friction or sliding friction is considered in friction calculations. The static regime and transition to sliding is ignored.
Static & Dynamic All three regimes are considered in friction calculations: static, transition to sliding friction, and sliding friction.
MU Static Enter a value for the static coefficient of friction, which has to be overcome by a body before it can move (> 0.0). *Not applicable for Dynamic Only.
Mu Dynamic Enter a value for the dynamic coefficient of friction that the body experiences while in motion (> 0.0 and < MU Static).
Stiction Transition velocity Enter a value for the velocity limit below which the coefficient of friction becomes MU static.
When the slip velocity is between stiction transition velocity and friction transition velocity, the coefficient of friction is in transition between the two (> 0.0). *Not applicable for Dynamic Only.
Friction Transition velocity Enter a value for the velocity above which the coefficient of friction becomes MU dynamic.
When the slip velocity is between stiction transition velocity and friction transition velocity the coefficient of friction is in transition between the two (> Stiction transition velocity).
Advanced
Find precise contact event Select this option to tell the solver to capture the first event of contact precisely.
Max. Step size scale factor Scale factor on the maximum step size the integrator would use to capture precise contact.
Change simulation max step size Select this option to change the maximum step size for the simulation after contact is detected.
New max step size New maximum step size value.
Force computed at Select the mesh location where force is computed.
Element Center The contact detection and force calculation in MotionSolve is based on the penetration of mesh element center. This is the default setting.
Nodes The contact detection and force calculation in MotionSolve is based on the penetration of mesh nodes.
Note & Tags
Note Optional descriptive note.
Attachment Candidates Add tags for the entity to use as possible attachments to Systems/Assemblies/Analyses.
Note:
  • For a rigid body, graphics of the type Primitives, FileGraphic, or CADGraphic could be included in contact. In the case of CADGraphic, MotionView will invoke HyperMesh in the background to obtain a mesh for the contact before sending the model to the solver.
  • Material Inside for a graphic indicates the graphic has material within the closed volume. Consequently, the surface normal of the geometry points outward of the graphic surface which indicates the side of contact. When the option is turned off, the surface normal of the geometry points inward. This flag is useful for reversing the surface normal to simulate internal contact.
  • Highlight contact side shows the side of contact, highlighted by a red color. A blue color indicates the side opposite to that of the contact side.
  • Use the Material Inside and Highlight contact side options in the Entity Editor to set the correct direction of contact.
  • Below are examples of how the Material Inside and Highlight contact side options work:
    • In this Rack & Pinion example, Material Inside is turned on for both graphics, and Highlight contact side shows a red color on surfaces on the external side, indicating the contact is external.
    • In the below example of spheres inside the box, the Box graphics Material Inside is turned off. Its surface from the outside appears in a blue color when Highlight contact side is clicked, indicating the flipping of the contact side (internal contact).
  • The individual graphics involved in contact should form a closed volume. In other words, the graphic mesh should not have any open edges or T-connections. Use the Highlight mesh errors option to check for open edges and T-connections. An open edge is highlighted through a red line, while a T-connection is highlighted using a blue line. For better visibility, the visualization of graphic components involved is changed to a non-shaded mode.
    Note: If no mesh errors are found, this option will be disabled and will display No mesh errors.
    Figure 3.
  • Activating Find precise contact event will automatically introduce a sensor entity in the MotionSolve solver deck which will track the contact force function.
  • As the sensor is triggered by a positive contact force, the solver rejects the last successful step and proceeds from the previous step size with a changed maximum step size. The changed maximum step size is calculated as (current max step size) * (Max step size scale factor).
  • Activating Change simulation max step size will enable changing the maximum step size for the future course of the of the simulation.
  • Both of the above options provide increased accuracy and robustness in contact simulations; however they will result in increased simulation times. It is therefore recommended that these options be used selectively and only when necessary.
Note on 2D Contacts
Note:
  1. The individual curve graphics involved in 2D contact must use planar curves only. A planar curve has all its data points in a single plane.
  2. Currently, MotionView only supports 3D Cartesian/parametric curves for creating curve graphics that can be used in 2D contact. Below is an example of how the Highlight contact side option works:
    Figure 4.
    The example above shows a rack and a pinion represented with curves and a 2D contact defined between them. The side of the pinion on which the arrows are pointing (which is outside) indicates the side the contact is expected. Similarly, the arrows on the pinion curve have arrows pointing on it from the outside.
  3. In the case where the contact is expected from the opposite side, the Flip Contact Side option in the Contact Graphics dialog can be used.
    • Click Flip Contact Side to specify the side of the curve graphic which will come in contact. The side of the curve as directed by the arrow indicates its contact side. Changing this flag will reverse the direction of contact.
    • In the Contact Graphics dialog, select Identify Planarity to check the planarity of the curves involved in contact. This tool checks whether the curves are planar and whether the curves are co-planar considering the first selected graphic in Body I as reference.
Note on Deformable Curve Contact
  • Radius value > 0 is needed for the selected deformable curve graphic to represent it as a tubular graphic in contact.
