Create Contacts Using the Contacts Tool
The Contacts tool allows you to create a contact force between two bodies, a body and deformable curve or a deformable surface, or between two deformable curves or two deformable surfaces.
- From the Model Browser, select the system to which the contact is to be added.
                Right-click on a system in the Model Browser and select  from the context menu.
                ORRight-click on a contacts folder in the Model Browser and select Add Contact from the context menu.ORFrom the Model ribbon, click the Contacts icon
.The Contacts guide bar is displayed. -
                Choose a contact combination from the drop-down menu choices.
Option Sub choices Description 3D Body - Body Use this combination to capture contact forces between two rigid or flexible bodies in a 3D frame. Body - Deformable Curve Use this combination to capture contact forces between a rigid or a flexible body and a deformable curve in a 3D frame. Body - Deformable Surface Use this combination to capture contact forces between a rigid or a flex body and a deformable surface in a 3D frame. Deformable Curve - Deformable Curve Use this combination to capture contact forces between two deformable curves in a 3D frame. Deformable Surface - Deformable Surface Use this combination to capture contact forces between two deformable surfaces in a 3D frame. 2D Rigid to Rigid Contact Use this type of contact to capture contact forces between rigid bodies moving relative to each other in a 2D plane. Point to Deformable Surface Contact Use this type of contact to capture contact forces between a deformable surface and a sphere of radius (r), where the sphere belongs to a second body.  -
                If 3D or 2D Rigid to Rigid
                    contact types are selected:
                If Point to Deformable Surface contact type is selected:
 - Optional:
                Click
 to reset the entity selections and select new
                    entities.
                Once the reference selections are made, create the
                        Contact using one of the following methods:
- Click
                        on the guide bar and use the microdialog to manage the contact options. - Click the
 button that appears at the mouse location in
                        the modeling window and use the microdialog to manage the contact options. - Click
 to create the entity and exit the guide bar selections for this Contact.
Once a contact entity has been added to the model, the entity will be in edit mode and its microdialog will appear in the modeling window. The Entity Editor for the contact will also displayed in the Entity Editor area. - Click
