Control SISOs
Use the SISOs tool to set control SISO data. This data can be used to add additional states to the mechanical system being modeled.
Create Controls SISOs
- From the Model Browser, select the system to which the Control SISO is to be added.
Right-click on a system in the Model Browser and select from the context menu.
ORRight-click on a Control SISO folder in the Model Browser and select Add Control SISO from the context menu.ORFrom the Model ribbon, click the SISOs icon.The Add Control dialog is displayed.
Specify a label for the control SISO.
The label can be changed at any time.
Specify a variable name for the control SISO.
By default, variables names of entities in MotionView follow a certain convention. For example, all control SISO entities have a variable name starting with “siso_”. This is the recommended convention to follow when building models in MotionView since it has many advantages in model editing and model manipulation.
Click OK to close the window or
Apply to continue creating entities.
Once a control SISO entity has been added to the model, the panel for the SISO will automatically be displayed in the panel area.
Edit Control SISOs
Define the Properties of Control SISOs
From the Properties tab, you can edit the control SISO data.
If the Control SISOs panel is not currently displayed, select the desired
controSISO by clicking on it in the Model Browser or in the
modeling window.
The Control SISOs panel is automatically displayed.
- Enter the coefficient values in the text boxes labeled Numerators and Denominators.
Click Append to add additional numerator and denominator
values.
Clicking Append adds a new numerator/denominator to the bottom of the list.Tip:
- Select the check box next to any of the values and click Insert to add a numerator/denominator directly above the selected entity.
- To delete a value, select any entity from the list and click Delete.
- Define the values for any added numerators or denominators.
Select the Static hold check
box.
Select this option if the state of the control SISO is not permitted to change during static and quasi-static analysis of the solver. Otherwise, deselect the option.
Define Control SISO Input
From the Input tab, you can set the input to the transfer function of the controller. You can enter initial condition values and enter linear, curve, or expression values.
- Click the Input tab.
- Click the Initial conditions check box and enter an initial condition value for the control SISO.
- Select an option from the Type drop-down menu.
Define the properties associated with your choice.
If Linear is chosen, enter a value in the text box.If Curve is chosen:If Spline3D is chosen:If Expression is chosen, enter an expression.
