Orientation
Use the Orientation tool to align an entity along a particular direction.
- Vectors
- Joints
- Bushings
- Markers
- Gears
There are two types of orientation tools:
- Vector Orientation
- This tool orients one axis or a vector. This tool is used to orient the
following entities:
- Vectors
- Non-compliant Joints
When in the edit context of an entity listed above, click on the Orientation tool. The VectorOrientation tool appears.Figure 1.
The tool is made up of a vector arrow indicating the direction and a plane orthogonal to the vector direction. The arrow tip has a circular handle. The tool is also accompanied with a microdialog containing a Point and a Vector icon to use as a filter for the method of orientation.
- Marker Orientation
- This tool orients a reference frame by the Axis-Plane method and is used
to orient:
- Markers
- Bushings and Compliant Joints
When in the edit context of entity listed above, click on the Orientation tool. The Marker Orientation tool appears.Figure 2.
The tool is made up of three directional vectors and two microdialogs:- The Orientation method selector to choose the Axes and Plane.
- A Filter for the method of orientation (containing a Point, Vector, and Direction Cosines icon).
