Views
This option is used to view the model in different perspective and also we can rotate the model in clockwise as well counter clock wise
Front Z : To view the model from top
Back Z : To view the model from bottom
Front Y : To view the model from left
Back Y : To view the model from right
Front X : To view the model from back
Back X : To view the model from front
Isometric view :
Rotate clockwise : To rotate the model along clockwise direction
Rotate Counterclockwise : To rotate the model along counterclockwise direction
Rotate Left : To rotate the model along left direction
Rotate Right : To rotate the model along right direction
Rotate Up : To rotate the model along Upward direction
Rotate Down : To rotate the model along downward direction
Lock Rotation: This option locks the rotation of the model.
