Volume
Display modified element during volume meshing
Turn on this toggle to display the modified surface elements after volume meshing and TET cleanup.
Retain surface normal during volume meshing
By default, volume meshing a body will correct the surface normal to point outwards. This toggle is used to skip the normal correction.
Kubrix Hex Mesher
Turn on this to enable the following tool: Mesh | 3D Create | Kubrix Hex Mesh.
By Default, this option is unchecked.
Use ASML boundary layer mesh
Turn ON this toggle to activate the ASML mesher to generate the boundary layers. By default, the mesher will utilize (N-1) number of cores, where N is the total number of available cores in the machine.
Limitations: Region, volume layers mesh controls are yet to be supported.
