Create the doors and windows of the building.
Create doors and windows.
On the Sketch tab, in the
Create group, click the
New Sketch icon.
Click on a face of the building where you want to place a
door/window.
Click the
button if the location
is correct.
Tip: If the location is not correct, drag the Move tool to
the correct location.
Rectangles icon and create a rough outline of the
door or window.
Dimension icon and
specify the exact lengths for the rectangle.
In the Assembly Browser, rename the sketch using the right-click
context menu.
In the Assembly Browser, select all the doors and windows sketches,
click Floor, and from the right-click context
menu, click .
Repeat Step 1 for each window
and door to be added.
