Navigating the Graphics Window
The graphics window is used to display and interact with the model. You can zoom, rotate and pan a 3D model using the keyboard, mouse, or a combination of both.
Panning the Model
Press and hold down the right mouse button, and drag the view to pan (without magnification).
Rotating the Model
Use one of the following methods to rotate the model:
- Press the mouse wheel and drag the view.Note: The rotation center point updates dynamically when clicking on the model.
- On the View toolbar, click the
Views icon and select one of
the following:
Rotate clockwise
Rotate counter clockwise
Rotate left
Rotate right
Rotate up
Rotate down
Zooming to Extents
Use one of the following methods to zoom the model to extents:
- Press
Fto zoom the model to the full extent of the graphics window. - On the View toolbar, click the
Fit View icon.
Zooming In / Out
Use one of the following methods to zoom in and out:
- Scroll the mouse wheel.
- Press Ctrl and hold, left mouse click and drag model.
