Defining a Radio Coverage Solution
Create a radio coverage solution for the model (bodies).
On the Solutions tab, in the
Solutions group, click the
Radio Coverage icon.
In the Assembly Browser, select model
SL_Sketch_Model.x_t.
The Select bodies field is populated with the contents of the model (bodies).
- Click OK to close the Create Solution dialog.
