Specifying the Propagation Model - DPM
Select the Dominant Path Model (DPM) as the computation method.
  1. In the Solution Browser, under the radio coverage solution created in Defining a Radio Coverage Solution, right-click on Settings.
  2. From the right-click context menu, click Solver Settings.
  3. On the Solver Settings dialog, in the Propagation model drop-down list, select Dominant Path Model (DPM).
  4. Click OK to close the Solver Settings dialog.
