Adding a Prediction Plane
Define a prediction plane where the results are to be predicted when running the WinProp Solver.
Note: A prediction plane (in XY plane) at a height of 1.5 m is created by
default.
On the Analysis tab, in the
Requests group, click the
Prediction icon.
- In the Mode drop-down list, select Global rectangular area.
- In the Resolution field, specify a resolution (grid) of 0.5 m.
- Under Corner Points, specify the X and Y coordinates of the prediction plane.
- In the Height(s) field, specify a height of 1.5 m.
- Click OK to close the Prediction dialog.
