Creating the Walls
Create the walls of the building by extruding the floor plan.
In the Assembly Browser:
  1. Duplicate Floor plan using the right-click context menu.
  2. Rename the duplicate to Wall using right-click context menu.
  3. Click Wall, and from the right-click context menu, click Extrude as Sheet Body.
  4. On the pop-up dialog, specify a height of 3 m.
The result is the following:
