Step 7: Feature Identifications in FEM
BOLT HOLE FACES
- Select the Connecting Rod FEM body in graphic area.
- Right click and choose Select Features.
- Turn ON the Cylinders toggle and enter the parameters min. and max. radius as 0 and 5 to identify bolt hole cylindrical faces.
- Also turn ON Create a Group toggle and name the group "Bolt_Holes" and click OK.
CONNECTING ROD SMALL END FACES
- Turn ON the Cylinders toggle and enter the parameters min. and max, radius as 9 and 11 to identify connecting rod small end cylindrical faces.
- Also turn ON Create a Group toggle and name the group "Small_End" and click
OK.
