Step 11: Assign Material and Property
Property for Solid
- Go to Analysis > Property > Property.
- Select Entity as Solid and choose Cast Iron from Material drop down list.
- Select the Connecting Rod FEM body in graphic area and click OK.
Note:
- Cast Iron material will be present in default under property browser along with few other frequently used materials like Steel and Aluminum.
- These materials will have the material parameters as per global standards and it can be edited by double clicking on it.
- Also new material can be created from Analysis > Property > Material.
Property for RBE
- Select Entity as Rigid Bar, Type as Rbe2 and define the RBE DOF.
- Select the RBE body in graphic area and click OK.
