Step 3: Feature Identifications in CAD
- Select Connecting Rod Body in the graphic area.
- Right click and choose Select Features.
- Turn ON the Fillets toggle and enter minimum radius as 0 and maximum radius as 5 as show below. Also, turn on the create group toggle and name the group as "Fillet_Group".
- Click Ok to identify the faces. The command is recorded as below:
