Step 4: Create Mesh Controls
Create Body Mesh Controls
- Select the Connecting Rod body in the graphic area.
- Go to Mesh > 2D Create > Mesh Controls.
- Select body mesh control and specify the Average element size as 4mm and click
OK.
Create Fillet Mesh Controls
- Select Fillet option and enter the parameters from the below picture.
- Then, select the Fillet_Group from group browser and click OK.
