Step 5: Surface Mesh
- Go to Mesh > 2D Create > Mesh
- Click on Advanced Options > Turn ON User defined model name and give "Connecting_Rod_Mesh" in line edit, then click OK.
- Select Connecting Rod Body in graphic area and click OK.
- The operation is recorded as below.
