Introduction of 2D Electrostatic
Presentation
The Electrostatic application allows the user to study the electric charges systems at equilibrium.
Use
Examples of Electrostatic applications are high voltage devices, spark-gaps, insulators, etc
Note: In this SimLab version it is mandatory to define a global unit system before creating a 2D Electrostatic Solution. Without a global unit system, the solving will not be carried out (limitation in the Flux solver).
To define the global unit system:
  1. Activate
  2. Choose the wanted system
    For more details on Unit System, please refer to the main page Unit System.
Links
Import CAD
Electrostatic Mesh
Mesh Controls
Surface Mesh
Quality Check (New)
Edit Solution
Material
Symmetry
Periodicity
Electric Field
Electric Potential
Electric Charge
Solution Settings
Solve
Results
