Mesh Controls
Mesh > Controls > Mesh Controls
Introduction
The mesh density and the quality can be controlled by assigning "Mesh Control" on the geometry. The "Mesh Control" can be assigned on geometry (Body, Face, Edge) or on Feature (Fillets, Cylinders) or on regions in space. The resulting mesh will be generated based on these "Mesh Controls".
Global and Local Mesh Control
Mesh controls can be a Global or a Local control. Global control is assigned to bodies or assemblies and all underlying geometry entities like faces, edges will inherit this global mesh controls. Suppose a local geometry, like a body, face, edge, are assigned a local mesh control, then the local mesh control will determine the mesh on these entities while the global mesh control will determine the mesh on rest.
CAD and Mesh Models
The mesh control can be assigned to CAD models that are imported into SimLab or to Mesh models created inside of SimLab. The mesh controls are also respected when meshing an assembly or a single body as well as when "Local Re-meshing" is called on a portion of the mesh body.
Almost all CAD models imported are manifold. In other words, there are no shared faces between 2 bodies. So meshing of a CAD assembly is the same as meshing individual bodies in the assembly. This is not the case when meshing an assembled mesh body. A mesh body can be a non-manifold, in other words faces and edges of a body can be shared by adjacent mesh bodies. In traditional FEM terms there are shared nodes between the 2 solids. When meshing mesh bodies with shared face, it is desired to a mesh that also has shared faces after meshing. The toggle "Assembly" in the global mesh control dialog box can be used to instruct the system to retain the non-manifold nature of the assembly during meshing.
Managing Mesh Control
When a mesh control is created with a given name, an entry with this name is added to the tree in "Mesh Control" tab in the "Model Browser". When creating a mesh control the geometry on which it is assigned has to be selected. Otherwise a mesh control cannot be created. Existing mesh control can be modified by double clicking the mesh controls in the tree view. A mesh control can be deleted by highlighting the mesh control in the tree view following by pressing the delete key on the key board.
When a mesh control is assigned on a face, the face changes color to indicate that a mesh control is assigned. The color for a mesh control can selected when creating or editing. Visual display of the mesh control can be turned ON/OFF by checking/un-checking the "Mesh Control" menu item under "Visibility". Mesh control visual display is disabled if View Toolbar > Render Mode > Color options is turned ON.
Mesh Specification File
Mesh control created can be saved in an external file, called "Mesh Specification" and saved file can be imported back into SimLab. This is very useful when meshing models of similar types when the mesh control created for one can be reused for the others. For example, the meshing requirements for modelling most engine heads are similar. So if a mesh control is created for one engine head model, then it is most likely that this can be reused for other engine head as well. This option also helps standardize the meshing process.
When creating mesh controls, geometry has to be selected. The selected geometry ids are stored with the mesh control. When a mesh control is exported the specification file can have the geometry ids. It is not necessary for two different CAD models to have the same ids for the geometry. So a mesh specification file that refers to ids for one CAD model will not be useful for another CAD model. So when exporting a mesh specification file one can choose to export with no geometry ids (Template option), with geometry ids (Body option), face color (Face color option) or group name (Group option).
When importing a mesh specification file that was exported with "Template" option, it will create mesh control objects in the "Mesh Control" tree view but with empty icons in the second column of the Model Browser. The empty icons indicates that these mesh controls have not been assigned to geometry. User can double click to open these mesh control and assign them to geometry and this will turn the mesh control object on the tree view to become bright.
Unit support
The mesh specification file will be exported in same unit system as that of the database.
If the exported mesh specification file has units, it should be imported only into a database where unit system is set ON. When the unit system of mesh specification and database is different, then the values in mesh specification file will be automatically converted to database unit system.
If the exported mesh specification file does not have unit system, it should be imported only into the database which does not have unit system.
Priority
When many "Mesh Controls" are assigned, it is possible that multiple "Mesh Controls" can have an influence on one geometry. For example, a face can have a local mesh size assigned as 5, while the body might have a mesh size of 10. What will be the mesh on the face? Another example will be 2 faces sharing an edge can have different mesh sizes. What will be the mesh size on the edge? The meshing code looks at all the mesh control and determines what size it should use for a geometric entity. For each geometry type the mesh size is determined as follows.
Edge
  1. Edge Mesh Seed
  2. Region Mesh Size
  3. Edge Mesh Size
  4. Smaller of the face mesh size on the faces connected to it.
  5. Feature Mesh Size
  6. Body Mesh Size
  7. Global Mesh Size (Size defined in the Surface Meshing dialog box)
Face
  1. Region Mesh Size
  2. Face Mesh Size
  3. Feature Mesh Size
  4. Body Mesh Size
  5. Global Mesh Size (Size defined in the Surface Meshing dialog box)
Body
  1. Region Mesh Size
  2. Body Mesh Size
  3. Global Mesh Size (Size defined in the Surface Mesh dialog box)
It is important to understand that the mesh size on geometry inside of a region as defined in "Region Mesh Control" ignores all geometry based mesh sizes other than the mesh seed.
For more information on Mesh Controls, please refer to Mesh Controls.
