Validate Mesh
Analysis > Mesh > Verify > Validate Mesh
The Validate Mesh tool performs a comprehensive integrity check to verify that all mesh bodies conform to solver compatibility requirements, including element quality, connectivity, and boundary condition consistency.
The following validations are performed:
  • Intersection Check – Detects intersecting elements within the mesh.
For 3D solutions, additional checks include:
  • Solid Body Check – Verifies that mesh bodies are volume meshed. Bodies used to represent thin region boundary conditions are excluded from this check.
  • Negative Volume Elements – Identifies elements with negative volume.
  • Periodicity Check – Verifies that periodic boundary conditions involving angular symmetry are properly satisfied.
Upon validation, messages indicating success or failure will be displayed. In case of any discrepancy found the failed entities will be organised into groups for easier identification.
Note: Script recording is not supported for this tool.
