Hole
The hole realization is dependent.
Realization Type
Rigid Element
A common realization for Implicit analysis that has a single node defined as the interface.
Rigid Patch
A common realization for Explicit analysis that has a meshed patch defined as the interface.
Element Type (Rigid Element)
This is the type of element the attachment creates:
  • RigidLink is a single RBE2
  • RBE2 is series of two legged RBE2s
  • RBE3 is a single RBE3
  • RBE3 (Stuck Node) is a specific Aerospace implementation of two RBE3s over the top of each other with differing DOFs
Weight Factor
The Weight Factor option is available when the element type is RBE3 or RBE3 (stuck node).
In the Abaqus profile, RBE3 and RBE3 (stuck node) realize constraint entities for which the weight factor methods are also supported.
Constant Weight
Specify a value which is going to be assigned to all nodes.
Inverse Distance
The weight factors are calculated based on the inverse of the distance between the dependent and independent node.
Normal Distribution
The weight factors are calculated based on the normal distance between the dependent and independent node.
Connect Outer Layer (Rigid Element)
How many layers into the mesh it will select, like washer layers.
None
Just the hole
Every Node
Single washer layer
Every other Node
Single washer layer alternating nodes
Two Layers
Two washer layers deep
Solid Hole Nodes (Rigid Element)
How do you want it to connect to solid holes.
  • Edge nodes: top and bottom edges only
  • Interior nodes: select all of the nodes in the interior hole
  • Face nodes: select only the nodes on the face of the solid hole
Snap to Center (Rigid Element)
Have the center of the rigid calculate based on the realization, or based on the location of the attachment entity.
Use Hole or Washer (Rigid Patch)
Fill Hole
Fill the hole with the patch
Use Washer
Create a patch on the washer layer of the hole
Use Both
Both the washer and the hole will be used
Create Elements (Rigid Patch)
Only available in OptiStruct, it will create a set instead of the patch elements.
