2026
View details for different types of realizations.
A list of realization types that can be specified for attachment connectors.
A single node that is considered. It’s for defining a connection point location only.
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
Connector preferences describe how different connector realizations behave when changes are made.
Use the Connector Browser to view and modify connectors in the current model.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
Create weld points at a predefined pitch distance so that the model build process can continue without the need to wait for the published weld data from CAD. The Auto Point tool is useful when working with elements, not geometry.
Use the Auto Fastener tool to identify and pair holes to create fastener connectors between components and parts. The process works on 2D/3D mesh.
Use the Auto Line tool to identify locations to create line connectors between components and parts. This process works on 2D geometry and mesh.
Use the Auto Area tool to identify locations to create area connectors between components and parts. This process works on mesh.
Create a dummy connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data.
Use the Quality controller to perform various checks on connectors and realized FE.
Use the FE Absorb tool to create connectors from existing mesh that meet specific types of realizations.
A list of realization types that can be specified for point connectors.
A list of realization types that can be specified for fastener connectors.
A list of realization types that can be specified for line connectors.
A list of realization types that can be specified for area connectors.
The hole realization is dependent.
A common realization for Explicit analysis that has a meshed patch defined as the interface.
Organize elements in the Browser Configuration dialog.
Create and add custom realizations in your workflow.
Attachments are an entity to facilitate the ease of joining subsystems.
Use the Connector tools to further define connections between components.
Abstract information incoming from the CAD hierarchy to robustly create connectors.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
