Wet Mixing Model
The Wet Mixing contact model allows you to add particles with moisture content (defined in the factory settings) to a simulation.
To add this model, navigate to Tools > Options > Solver Options > Experimental Contact Models.
This model is aimed at cement applications as the moisture can be transferred to drier particles while mixing. The level of moisture in the model alters the interaction behavior of the particles.
Note: This model is an experimental model added to EDEM.
Specify the following details for the Wet Mixing model:
For Specify
Minimum Relative Distance Indicates the Lower-bound for how close two surfaces can be. Due to surface roughness, this is expressed as a percentage in decimal form.
Surface Tension Indicates the surface tension based on the liquid which is being represented and can be found in engineering databases.
Wetting Angle Indicates the angle where the surface meets the liquid.
