EDEM Creator
EDEM Creator is the pre-processor for creating an EDEM simulation model, including setting up equipment and defining the generation of bulk materials.
Use EDEM Creator to:
  • Set up simulations quickly and logically using EDEM's intuitive and user-friendly interface
  • Import equipment Geometry from various CAD files (IGES, STL, STEP, and more)
  • Assign motion to equipment (linear, rotational, sinusoidal, force, torque driven motions, and so on)
  • Model particle shapes using Multi-Sphere, Polyhedral, and Sphero-Cylindrical particle shapes
  • Automatically create complex shapes using the Sphere Fitting tool
  • Easily create flexible materials and fibers using the Meta-Particle feature
  • Select an appropriate, highly validated Physics model from a wider range of options
EDEM Creator allows you to set up and initialize your model. It is where you import particles and Geometries and define the other model parameters.
  1. The Creator Tree
  2. The Viewer
  3. The Toolbar and Menu Bar
  4. The Data Browser
  5. The Tree Filter
The Creator Tree
The Creator Tree is displayed on the left side of the EDEM window. It contains information about the Project, Bulk Material, Equipment Material, Geometries, Physics, and Environment.
The Viewer
The Viewer displays 3D representations of your particles, Geometry, and fields (if applicable). You can control the rotation, position, and zoom factor of the Viewer using a mouse. There are a number of animation controls displayed below the Viewer.
Icon Name Description
Creator Opens EDEM Creator
Simulator Opens EDEM Simulator
Analyst Opens EDEM Analyst
New Creates a new model
Open Opens an existing model
Save Saves an existing model
Help Displays the online Help
Change Time Step Back Moves to the first Time Step in the simulation
Change Time Step Forward Moves to the last Time Step in the simulation
Start Coupling Server Starts the Coupling Server
Coupling Server Disabled Disables the Coupling Server
Server Awaiting Connection Indicates that the Coupling Server has started but is not connected
Server Connected Indicates that the Coupling Server is connected
Stop Server Stops the Coupling Server
Filled Display Mode Displays Geometry as filled
Mesh Display Mode Displays Geometry as a mesh
Points Display Mode Displays Geometry as points
Display Particles Displays or hides all particles
Display Cylindrical Periodic Boundary Conditions Displays cylindrical periodic boundary conditions
Add Bulk Material Adds Bulk Material to the simulation
Add Equipment Material Adds Equipment material to the simulation
Save Material Block Saves a block of material for a material bed
Transfer Material from Database Materials Transfers materials to and from the Material Database
Rename Material Renames the selected material
Copy Material Copies the selected material
Delete Material Deletes the selected material
Open GEMM Wizard Opens the GEMM Wizard
Add Particle Adds a particle to the Bulk Material
Import Particle Imports a particle
Export Particle Exports a particle
Rename Particle Renames a particle
Copy Particle Copies a particle
Delete Particle Deletes a particle
Add Sphere Adds a sphere to the particle
Copy Sphere Copies a particle Sphere
Delete Sphere Deletes a particle Sphere
Add a Geometry Adds a Geometry
Add a Box Adds a box from the Geometry dropdown list
Add a Cylinder Adds a cylinder from the Geometry dropdown list
Add a Polygon Adds a polygon from the Geometry dropdown list
Import a Geometry Imports a Geometry from a 3D CAD file
Rename a Geometry Renames Geometry sections
Copy a Geometry Copies Geometry sections
Delete a Geometry Deletes Geometry sections
Merge a Geometry Merges Geometry sections
Replace a Geometry Replaces a Geometry section with an alternative Geometry
Add a Motion Click to add a motion from the dropdown list
Add Linear Translation Adds linear translation to a Geometry
Add Linear Rotation Adds linear rotation to a Geometry
Add Sinusoidal Translation Adds sinusoidal translation to a Geometry
Add Sinusoidal Rotation Adds sinusoidal rotation to a Geometry
Add Conveyor Translation Adds conveyor translation to a Geometry
Add Conveyor Rotation Adds conveyor rotation to a Geometry
Rename a Motion Renames a motion
Copy a Motion Copies a motion and applies to the current Geometry or an alternative Geometry
Delete a Motion Deletes a motion
Move Motion Up Reorders the motion
Move Motion Down Reorders the motion
Add Force Adds force to the Geometry
Add Torque Adds torque to the Geometry
Add Factory Adds a material factory to the simulation
Import Factory Imports a factory
Rename Factory Renames a factory
Copy Factory Copies a factory
Delete Factory Deletes a defined factory
Change Factory Changes from static to dynamic factory
Add Material Block Adds a material block to a Geometry
Delete Material Block Deletes a defined material block
Show Scale Grid Shows/hides grid while displaying particle shapes
Show Origin Shows origin and particles as a mesh when displaying particle shapes
Highlight Surface/Meta-Particle Highlights the selected surface of particle shape/selected Meta-Particle
Add Meta-Particle Adds a Meta-Particle
Rename Meta-Particle Renames a Meta-Particle
Copy Meta-Particle Copies a Meta-Particle
Delete Meta-Particle Deletes a Meta-Particle
Note: In addition to the icon system, a series of keyboard shortcuts in the Creator Tree help you perform the same tasks. You can use the Delete key for single and multiple selections.
Menu Bar
File Menu
Save Saves the current model
Save As Saves the current model with a specific name, or to a specific location
Geometry Transforms Exports Geometry transforms
Import Config Imports a config (*.dfg) file
Export Config Exports a config (*.dfg) file
Creator Starts EDEM Creator
Simulator Starts EDEM Simulator
Analyst Starts EDEM Analyst
Recent Files Displays a list of recently opened files
Quit Exits EDEM
Note: For more information about how to configure and set options, click Tools > Options..., and see Set Options.
View Menu
Show Particles Select to turn the particle display in the Creator on or off.
Parent-Child Lines Select to show how Geometries are connected using the Parent-Child hierarchy. Lines will be drawn between connected Geometries.
Geometry Origin Axes Select to see the axes per Geometry element.
Themes Select Legacy (default) or Dark Theme for the EDEM interface
Toggle Display Command Line Output Can be used for debugging. In certain scenarios, this can be used to display specific error warnings.
Displays Menu
Show 1 Display Shows the EDEM window in a single display.
Show 2 Displays Shows the EDEM window in two viewer displays to review different view-points of the model within each window
Show 3 Displays Shows the EDEM window in three viewer displays to review different view-points of the model within each window
Show 4 Displays Shows the EDEM window in four viewer displays to review different view-points of the model within each window
Split Display Horizontally Splits the displays horizontally so that simulations may be simultaneously reviewed qualitatively and quantitatively on the same display
Split Display Vertically Splits the displays vertically so that simulations may be reviewed both qualitatively and quantitatively on the same display
Help Menu
Help Displays information about the EDEM interface
About EDEM Displays the current version of EDEM. The EDEM Version and Revision number are useful for EDEM Technical Support when discussing support cases.
About Altair Simulation Products Displays the Copyright notices, Altair website, License Agreements, and Customer Support information.
The Data Browser
The Data Browser is an .html page that displays detailed information about your model. The information displayed is different in the Creator, Simulator, and Analyst. Right-click the Data Browser and select Save to save the information in an .html file.
The Data Browser comprises the following sections:
Section Description
Description Available in the Project section of the Creator Tree
General Gravity
Displays details of the gravity acting in your model as specified in the Creator Tree
Materials
Lists all the materials used in the model and their properties, as specified in the Materials Editor
Energy
Displays the total energy in the model at the current time, which is the sum total of the kinetic energy, potential energy, and the energy in any contacts taking place
Geometry Domain
Lists the dimensions of the domain as specified in the Creator Tree
Sections
Lists each section(model) and its properties
Geometry Totals
Aggregates the details of the number of elements that make up each section of the Geometry
Particles Particles
Lists each particle type used in the model and their properties. This contains either sphere data for Multi-Sphere, and Sphero-Cylinder data or mesh data for polyhedral particles.
Factories
Lists the details of each factory used in the model and their properties as specified in the Creator Tree. The total number of particles created by each factory is also listed.
Particle Totals
Lists the total number of particles in the model at the current time and for each particle type
Contacts Interactions
Lists the interaction types taking place in the model as specified in the Materials Editor
Contact Totals
Lists the total number of contacts in progress at the current time. The contacts are broken down into contact types. For example, the number of particle A - particle B contacts or number of particle B - surface A contacts. The total number of collisions that have taken place during the Time Step are also listed.
The Tree Filter allows you to filter items in the tree by entering a part of the item name. Within the tree, only items/child items that match the filter will be displayed. All other items are hidden from the view.
Filter Options
Case Sensitive Select to make string-based comparisons case-sensitive. By default, this option is unselected.
Fixed String Select to perform string-based matching.
Wildcard Select to perform string-based matching with wildcard characters. '?' matches a single character. '*' matches one or more characters.
