Creator Tree-Bulk Material
Creator Tree-Bulk Material allows you to add bulk material and bulk material particle shapes to a model and define their interactions.
The Bulk Material section of the Creator Tree allows you to select the bulk material required for a simulation, define the material inlet region, and specify the mass flow rate into the system. Every particle or piece of Geometry in a model is made of a specific material.
You must define all materials as well as their interactions in the Bulk Material or Equipment Material tree in the EDEM Material Model database. You can create materials either in the simulation or import materials from the Materials Database. The model contains all the materials defined in the Materials section.
