Creator Tree-Geometries
Creator Tree-Geometries allows you to use Geometry sections to construct the environment in which your bulk material interacts.
You can use any number of Geometries to create the equipment. Geometries can be built from imported CAD Geometries, n-sided polygons, boxes, or cylinders from within EDEM. All Geometries are stores as meshes. For example, a ten-sided polygon has ten elements and a square surface has two elements.
