2026
EDEM Creator is the pre-processor for creating an EDEM simulation model, including setting up equipment and defining the generation of bulk materials.
Creator Tree-Physics allows you to add Physics interactions.
EDEM is a high-performance simulation software for bulk and granular materials.
This section details the minimum system requirements and requisites for running EDEM.
This section contains information about the EDEM 2026 release, such as key features, enhancements, and bug fixes.
Start using EDEM with our interactive tutorials.
The EDEM user interface comprises three icons for each simulation component - Creator, Simulator, and Analyst.
Creator Tree-Project allows you to define the title and description for the simulation.
Creator Tree-Bulk Material allows you to add bulk material and bulk material particle shapes to a model and define their interactions.
Creator Tree-Equipment Material allows you to add equipment material to a model and define interactions between materials.
Creator Tree-Geometries allows you to use Geometry sections to construct the environment in which your bulk material interacts.
Creator Tree-Environment allows you to define global settings for the simulation in the Environment section.
You can create a list (stack) of automatically arranged Physics models, where the top element is applied first, followed by the next one below it, and so on.
EDEM Simulator is a powerful solver used for fast and efficient simulations.
EDEM Analyst is the post-processor used to analyze and visualize the results of your simulation.
A Contact Model describes how elements behave when they come into contact with each other.
EDEM Cal is a utility which works with EDEM and is designed to assist in performing calibration.
The EDEM Calibration kits are a collection of EDEM models of standard bulk solids characterization tests commonly used for EDEM material model calibration.
The EDEM CUDA GPU module uses the latest General Purpose Computing on Graphical Processing Units (GPU) technology.
The EDEM Programming Guide describes the EDEM API.
The Coupling Interface Programming Guide provides an overview of how to use the EDEM Coupling Interface to couple with a generic CFD code and/or Multi Body dynamics codes.
EDEMpy is a Python library for accessing EDEM data from .h5 files (the underlying EDEM file format). EDEMpy does not require prior knowledge of advanced programming.
.h5
EDEM contains four solver engines.
This section provides additional information about how to estimate simulation time, supported EDEM File types, attribute definitions, and so on.
Definitions of terms used in EDEM.
This section cites the contributions made by various authors and sources that have been used as reference material for EDEM, and the specifics of how they have been applied can be found in the individual contact model sections.
