Creator Tree-Equipment Material
Creator Tree-Equipment Material allows you to add equipment material to a model and define interactions between materials.
The difference between Equipment and Bulk materials is that Equipment materials do not have a defined particle shape or size distribution. Bulk materials can also be assigned to Factories, whereas Equipment materials can only be assigned to Geometries.
