Contact Model and GPU Device Compatibility
The Multi-Sphere solver can run on two different engines such as CPU and CUDA.
The engine to be used will be determined by the hardware as well as the simulation settings. The GPU engines (CUDA) can only be used when all models in a simulation are supported; otherwise, the entire simulation will run on the CPU if only some of the Physics models are supported on the GPU. In order to understand which models take full advantage of the GPU engine, select the Solvers tab in the EDEM Physics Interaction section of the Creator.
Models | Name | CPU | CUDA |
Base Models | Hertz-Mindlin (no slip) | ● | ● |
Hertz-Mindlin with JKR** | ● | ● | |
Hertz-Mindlin with JKR V2 | ● | ● | |
Linear Spring | ● | ● | |
Hysteretic Spring | ● | ● | |
Edinburgh Elasto-Plastic Adhesion | ● | ● | |
No Base Model | ● | ● | |
Rolling Friction Models | Standard Rolling Friction | ● | ● |
RVD Rolling Friction (Deprecated) | ● | ● | |
Type C Rolling Friction | ● | ● | |
No Rolling Friction Model | ● | ● | |
Additional Models | Bonding (Deprecated) | ● | |
Bonding V2 | ● | ● | |
Breakage | ● | ● | |
Heat Conduction | ● | ● | |
Linear Cohesion V2 | ● | ● | |
Tribocharging | ● | ||
Electrostatics | ● | ||
Relative Wear | ● | ● | |
Archard Wear** | ● | ● | |
Spray Coating | ● | ● | |
Particle Body Forces | Electrostatics | ● | |
Temperature Update | ● | ● | |
Saffman Lift | ● | ● | |
Magnus Lift | ● | ● | |
Schiller and Naumann Drag | ● | ● | |
Morsi and Alexander Drag | ● | ● | |
Haider and Levenspiel Drag | ● | ● | |
Ganser Drag | ● | ● |
If an API model is written with the GPU API (API code includes the relevant CUDA file), the status of the GPU Solver Mode will change from CPU Solver to GPU Solver. Contact Chaining for GPU API is supported. However, only one plug-in model is supported at the same time. If the API is a Base contact Model, you must not further add in-built base contact models to the simulation.
For more information about the GPU Solver, see the GPU CUDA Guide.
