Base Contact Models
Base Contact models define the physical collision between particle materials or particles and geometries.
The Base Contact model consists of spring and damping forces in the normal and
tangential directions. You can add only one base model per simulation.
For simulations using a custom API Contact model, select No Base Model in the Base Model dropdown list.
