Hertz-Mindlin with JKR Version 2 Model
The Hertz-Mindlin with JKR Version 2 (JKR V2) model captures the behavior of multiple materials and uses a more accurate implementation of the JKR theory.
The Johnson-Kendal-Roberts Theory of Adhesion (also known as the JKR Model) is typically used for calculating the contact forces acting on elastic and adhesive particles and assumes that the attractive forces are short range. To date, a large number of studies on many different particulate systems have been reported in the literature using the JKR model. However, most of them use a simplified version of the JKR model that depends on the surface energy of the particles involved in the contact and also for cases where materials of the same type are involved too. It calculates the additional work required to break the contact (adhesion) after the physical detachment of particles, thus making it applicable to contacts involving very small particles.
Particles may adhere together in a number of ways depending on the type of bond formed. For very small particles (smaller than 100 µm), van der Waals forces become significant and particles tend to stick to each other.
The model is suitable for elastic and adhesive systems and the force-overlap response of the JKR model is shown. It states that when two elastic and adhesive spheres approach each other, the force acting on the spheres is zero (from A to B). The DEM contact between these two spheres is established when they physically come into contact (B), and the normal contact force immediately drops to 8/9fc, where fc is the pull-off fore due to the presence of the van der Waals attractive forces (C). Upon loading the two spheres, the normal contact force follows the trend from C to D. During the recovery stage (unloading), the stored elastic energy is released and is converted into kinetic energy which causes the spheres to move in the opposite direction. All the work done during the loading stage is recovered when the contact overlap becomes zero (C). However, at this point, the spheres remain adhered to each other and further work is required to separate the two spheres (within the area highlighted in red). In order to break the contact, a minimum force equal to the pull-off force (E) is required and the contact breaks at F.
In order to account for the work of adhesion, the EDEM contact radius must be activated and set to be greater than the physical radius of the particle as follows:
EDE M contactradius ≥r+ α f MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyraiaads eacaWGfbGaamytamaaBaaaleaacaWGJbGaam4Baiaad6gacaWG0bGa amyyaiaadogacaWG0bGaamOCaiaadggacaWGKbGaamyAaiaadwhaca WGZbaabeaakiabgwMiZkaadkhacqGHRaWkdaabdaqaaiabeg7aHnaa BaaaleaacaWGMbaabeaaaOGaay5bSlaawIa7aaaa@4F0E@
Where r is the physical particle radius and αf is the relative approach where the contact breaks. The range of values where the EDEM contact radius can be considered valid should be defined prior to the simulation by using equations 3 and 5.
Note: In EDEM simulations, in order to account for work of adhesion, it is important to increase the contact radius of the particle by selecting EDEM Creator > Bulk Material > Particle. The contact radius being greater than the physical radius allows the influence of a negative overlap in the force calculations. The following figure describes the Loading and Unloading behavior of the JKR model.
The normal contact force (or adhesion force) in the JKR V2 model is defined as:
F n = 4 E * a 3 3 R * − ( 8 π Γ E * a 3 ) 1 2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGUbaabeaakiabg2da9maalaaabaGaaGinaiaadweadaah aaWcbeqaaiaacQcaaaGccaWGHbWaaWbaaSqabeaacaaIZaaaaaGcba GaaG4maiaadkfadaahaaWcbeqaaiaacQcaaaaaaOGaeyOeI0Iaaiik aiaaiIdacqaHapaCcqqHtoWrcaWGfbWaaWbaaSqabeaacaGGQaaaaO GaamyyamaaCaaaleqabaGaaG4maaaakiaacMcadaahaaWcbeqaamaa CaaameqabaWaaSaaaeaacaaIXaaabaGaaGOmaaaaaaaaaaaa@4B55@
Where E*, R*, Γ, and a are the relative elasticity, relative radius, interfacial surface energy (also known as work of adhesion) and contact radius (as described in Thornton, 2015, respectively, which is not the same as the EDEM contact radius. In this implementation of the model, the adhesive force depends on the interfacial surface energy and the relative approach (negative) at which the contact breaks and are defined as:
Γ = γ 1 + γ 2 − γ 1 , 2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeu4KdCKaey ypa0Jaeq4SdC2aaSbaaSqaaiaaigdaaeqaaOGaey4kaSIaeq4SdC2a aSbaaSqaaiaaikdaaeqaaOGaeyOeI0Iaeq4SdC2aaSbaaSqaaiaaig dacaGGSaGaaGOmaaqabaaaaa@435B@
α f = 3 F 2 n c 16 R * E * 2 1 3 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySde2aaS baaSqaaiaadAgaaeqaaOGaeyypa0ZaaeWaaeaadaWcaaqaaiaaioda caWGgbWaaWbaaSqabeaacaaIYaaaaOWaaSbaaSqaaiaad6gacaWGJb aabeaaaOqaaiaaigdacaaI2aGaamOuamaaCaaaleqabaGaaiOkaaaa kiaadweadaahaaWcbeqaaiaacQcacaaIYaaaaaaaaOGaayjkaiaawM caamaaCaaaleqabaWaaSaaaeaacaaIXaaabaGaaG4maaaaaaaaaa@4735@
Here, γ1 and γ2 are the surface energies of the two spheres and γ1,2 is the interfacial surface energy. For the special case where two spheres of the same material come into contact, the interfacial surface energy is zero γ1,2 = 0 , and the interfacial surface energy becomes Γ = 2γ.
The relative approaching distance, α, (also known as contact overlap) and the pull-up force are defined as:
α = a 2 R * − 2 π Γ a E * 1 2 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdeMaey ypa0ZaaSaaaeaacaWGHbWaaWbaaSqabeaacaaIYaaaaaGcbaGaamOu amaaCaaaleqabaGaaiOkaaaaaaGccqGHsisldaqadaqaamaalaaaba GaaGOmaiabec8aWjabfo5ahjaadggaaeaacaWGfbWaaWbaaSqabeaa caGGQaaaaaaaaOGaayjkaiaawMcaamaaCaaaleqabaWaaWbaaWqabe aadaWgaaqaamaaCaaabeqaamaalaaabaGaaGymaaqaaiaaikdaaaaa aaqabaaaaaaaaaa@4762@
F n c = 3 2 π R * Γ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGUbGaam4yaaqabaGccqGH9aqpdaWcaaqaaiaaiodaaeaa caaIYaaaaiabec8aWjaadkfadaahaaWcbeqaaiaacQcaaaGccqqHto Wraaa@403F@
Where a is the normal overlap between particles. For contacts between spheres of the same material, Γ = 2γ. Therefore, equations for 1 and 4 can be rewritten as follows:
F n = 4 E * a 3 3 R * −4 (πγ E * a 3 ) 1 2 MathType@MTEF@5@5@+= feaahGart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBa aaleaacaWGUbaabeaakiabg2da9maalaaabaGaaGinaiaadweadaah aaWcbeqaaiaacQcaaaGccaWGHbWaaWbaaSqabeaacaaIZaaaaaGcba GaaG4maiaadkfadaahaaWcbeqaaiaacQcaaaaaaOGaeyOeI0IaaGin aiaacIcacqaHapaCcqaHZoWzcaWGfbWaaWbaaSqabeaacaGGQaaaaO GaamyyamaaCaaaleqabaGaaG4maaaakiaacMcadaahaaWcbeqaamaa CaaameqabaWaaSaaaeaacaaIXaaabaGaaGOmaaaaaaaaaaaa@4B94@
α= a 2 R * −2 πγa E * 1 2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdeMaey ypa0ZaaSaaaeaacaWGHbWaaWbaaSqabeaacaaIYaaaaaGcbaGaamOu amaaCaaaleqabaGaaiOkaaaaaaGccqGHsislcaaIYaWaaeWaaeaada Wcaaqaaiabec8aWjabeo7aNjaadggaaeaacaWGfbWaaWbaaSqabeaa caGGQaaaaaaaaOGaayjkaiaawMcaamaaCaaaleqabaWaaWbaaWqabe aadaWgaaqaamaaCaaabeqaamaalaaabaGaaGymaaqaaiaaikdaaaaa aaqabaaaaaaaaaa@479D@
Note: The corresponding relative approach in the JKR model, a, is independent from the contact radius that you prescribe in EDEM. The latter is only used to activate the model and the JKR force will be calculated as described and applied for both positive and negative overlaps.
