Particle Body Force Contact Models
You can define a particle body force to act on particles when a specified condition is met, when particles are in certain positions, or are traveling at a specified velocity.
Using the Interaction dropdown list, you can create a list (stack) of particle body forces. The top element is applied first, then the next one down and so on. Use the arrow icons to move the force up and down the list. To remove an item, click the X icon. Click Preferences to configure the selected model.
