Temperature Update Model
The Temperature Update contact model must be used in combination with the Heat Conduction contact model to ensure the function of the Heat Conduction algorithm as described in (Chaudhuri, Muzzio and Tomassone 2006).
This model is originally designed and validated with the Hertz-Mindlin Base model only. After calculating all the heat fluxes, the temperature change over time of each particle is updated explicitly using:
| Interaction | Configurable Parameters | Position |
| Particle to Particle (heat conduction) | Set the thermal conductivity for each type of particle. Note: The unit depends on the temperature unit;
for example, the unit will be W/mK when the temperature unit is
Kelvin. |
Last |
| Particle to Geometry(heat conduction) | Set the thermal conductivity for each type of particle for the particle-geometry contact. | Last |
| Particle Body Force (temperature update) | Set the specific heat capacity of the particle. | N/A |
| Name | Description and Parameter Values |
| Temperature Update | Although not strictly a force, this built-in model allows the
modeling of model external heat sources acting on the particles. You
must use this model with the Hertz-Mindlin and the Heat Conduction
contact model as it also completes the calculation of heat transfer
between particles in contact. Set the specific heat capacity for each type of particle. The unit depends on the temperature unit; for example, the unit will be Jkg-1K-1 when the temperature unit is Kelvin. |
