Drag Model
The Drag contact model is the most commonly used drag model for spherical and non-spherical particles (based on sphericity).
The drag force is the primary contributor to particle motion in practically all
particle-laden flows. Therefore, this force needs to be calculated precisely in order to
simulate particle-fluid flows successfully.
| Name | Description and Parameter Values |
| Schiller and Naumann Drag | This drag model requires an imported velocity vector field or user-defined flow field. In addition, you specify the fluid density and viscosity and particle scale factor used. |
| Morsi and Alexander Drag | This drag model requires an imported velocity vector field or user defined flow field. In addition, you must specify the fluid density and viscosity and particle scale factor used. |
| Haider & Levenspiel Drag | You must specify the sphericity of each particle type used (default of 1 is a perfect sphere). This value is used in the drag calculation to account for non-spherical particles. This drag model requires an imported velocity vector field or user defined flow field. In addition, you must specify the fluid density and viscosity and particle scale factor used. |
| Ganser Drag | You must specify the sphericity of each particle type used (default of 1 is a perfect sphere). This value is used in the drag calculation to account for non-spherical particles. This drag model requires an imported velocity vector field or user defined flow field. In addition, you must specify the fluid density and viscosity and particle scale factor used. |
Note:
- You cannot apply more than one Drag model to the simulation. However, this is not recommended as the Drag models are designed as stand-alone models.
- After selecting and applying a Drag model, you must import a Velocity field using the Field Data Manager or specify a fixed velocity in the Drag model.
- This model requires an imported velocity vector field called 'velocity' (in lower case) or a user-defined flow field.
