Lift Model
Lift models allow you to add a lift force to particles. This is applicable in scenarios where the particles are interacting with fluids.
| Name | Description and Parameter Values |
| Saffman Lift | The Saffman lift force is developed due to the pressure
difference on a particle under a non-uniform shear velocity field.
You specify the density and viscosity of the flow field and the
particle scale if the particles have been scaled up. The Staffman
lift force requires a vorticity vector field called vorticity to be
imported using the Field Data Manager in order to calculate the lift
force. The model also requires a velocity field called velocity to be imported or the user-defined steady state flow field applied. Simulations can contain both Magnus and Saffman lift forces in addition to one of the Drag models. |
| Magnus Lift | The Magnus lift force is developed due to rotation of particles.
particle scale if the particles have been scaled up. The Magnus lift
force requires a vorticity vector field called vorticty to be
- You can add one or more Lift Models to the simulation.
- After selecting and applying a Lift model, you must import a Velocity field using the Field Data Manager or specify a fixed velocity in the Lift model.
