Hardware Requirements
This section details the minimum system requirements and requisites for running EDEM.
Component | Minimum | Recommended |
RAM | 8 GB | 32 GB or more |
Processor |
Graphics Display |
Graphics Driver support for OpenGL 4.5 or later |
CPU GPU Simulation |
Note: Only NVIDIA GPU cards support the
EDEM CUDA GPU Solver. Other
NVIDIA GPU cards are supported within the ranges
highlighted.
Hard Disk Drive | 100 GB (4 GB for the software) | 1 TB or more for simulation data files |
*CUDA GPU is required for simulations using Sphero-Cylinder and Polyhedral particles. Multi-Sphere simulations are supported on both CPU and CUDA GPU solvers.
Supported Platforms | ||
OS | Version | Architecture |
Windows |
x86_64 |
Linux |
x86_64 |
For more hardware information about EDEM, see:
Note: EDEM requires OpenGL and other
supporting libraries which cannot be included in the EDEM installer. For Linux, the following command will install the minimum number of
packages to provide all the required
libraries:
sudo dnf install mesa-libGL* libglvnd-* --exclude="*-devel*"
