Electrostatics Model
The Electrostatics contact model allows you to add electrostatic forces to the existing kinematic forces in the Particle Body Force section.
Electrostatic force is a force between particles exerted due to their charge, and can be either attractive or repulsive. Since the EDEM Electrostatic model uses Electrostatic screening, you must specify the size of a screen when using this model. Particles outside the screen will be removed from electrostatic force calculations on the central particle as shown:
The screened Coulomb force Fs is defined as:
Fs=q1q24π0kr+1r2ekr MathType@MTEF@5@5@+=feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOramaaBaaaleaacaWGZbaabeaakiabg2da9maalaaabaGaamyCamaaBaaaleaacaaIXaaabeaakiaadghadaWgaaWcbaGaaGOmaaqabaaakeaacaaI0aGaeqiWdaNaeyicI48aaSbaaSqaaiaaicdaaeqaaaaakmaabmaabaWaaSaaaeaacaWGRbaabaGaamOCaaaacqGHRaWkdaWcaaqaaiaaigdaaeaacaWGYbWaaWbaaSqabeaacaaIYaaaaaaaaOGaayjkaiaawMcaaiaadwgadaahaaWcbeqaaiabgkHiTiaadUgacaWGYbaaaaaa@4CC4@
Where q1 and q2 are the charges of two particles, r is the distance between their centers, and ε0 is the permittivity of free space (8.854 X 10-12 Fm-1). κ is an inverse of the Debye length, λD.
k=qe10KBTinizi2 MathType@MTEF@5@5@+=feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=xfr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4Aaiabg2da9iaadghadaWgaaWcbaGaamyzaaqabaGcdaGcaaqaamaabmaabaWaaSaaaeaacaaIXaaabaGaeyicI4SaeyicI48aaSbaaSqaaiaaicdaaeqaaOGaam4samaaBaaaleaacaWGcbaabeaakiaadsfaaaWaaabuaeaacaWGUbWaaSbaaSqaaiaadMgaaeqaaOGaamOEamaaBaaaleaacaWGPbaabeaakmaaCaaaleqabaGaaGOmaaaaaeaacaWGPbaabeqdcqGHris5aaGccaGLOaGaayzkaaaaleqaaaaa@4B41@
Where
  • qe is the charge of an electron (1.602 X 10-19C)
  • ε is the relative permittivity of the medium. EDEM uses a value of 1, which is a relative permittivity of a vacuum.
  • Kb is the Boltzmann’s constant equal to 1.38 X 10-23 JK-1.
  • T is the temperature in Kelvin, EDEM uses a value of 295.4K.
  • The last term is the local charge concentration (where n is the number of particles of charge z).
