The Relative Wear contact model is used to identify regions of high impact (normal)
and abrasive (tangential) wear on the equipment within a simulation.
The wear is calculated based on the relative velocity and associated forces
between the bulk material and the equipment. You can use the data from this model to
identify the areas where wear is occurring. While it gives quantitative values for
contrast between two or more design iterations, it does not explicitly calculate the
rate of material removal.
The four relative wear properties are Normal Cumulative
Contact Energy, Tangential Cumulative Contact Energy, Normal Cumulative Force and
Tangential Cumulative Force. Normal and Tangential Energy measure the cumulative
energy due to material impacting and sliding respectively.
Where Vn is the normal relative
velocity and is negative in a loading situation.
Where Vt is the tangential relative
velocity.
When
The Fnc is the cumulative peak
forces of the different contacts occurring on a Geometry element.
| Interaction |
Configurable Parameters |
Position |
| Particle to Particle |
None |
Last |
| Particle to Geometry |
Indicates the Record Relative Wear (On/Off).The Relative Wear
model is a way of identifying regions of high impact (normal)
simulation. It is calculated based on the relative velocity and
associated forces between the bulk material and the equipment.
This model provides you with additional data to indicate regions
in which wear is taking place. Whilst it provides quantitative
values for comparison between two or more design iterations, it
does not determine an explicit material removal rate. |
Last |
Note:
- The tangential cumulative force is dependent on the Time Step that you
select. The smaller the Time Step, the larger the cumulative force.
- The Relative Wear model does not take into account the size of each
element so a large variation in mesh sizing might produce unexpected
results.
