Archard Wear Model
The Archard Wear contact model extends any Base Model to provide an estimation of wear depth for geometry surfaces.
The model is based on the work by John F Archard (Archard 1953) and
uses the idea that the amount of material removed from the surface will be proportional
to the frictional work done by particles moving over the surface.
The Archard equation is defined as:
Where Q is the volume of material removed, dt is the tangential distance moved and W is a wear constant originally defined as:
Where K is a dimensionless constant and H is a hardness measure of the softest surface (based on the Vickers hardness in units of Pa). This was reduced to a single wear constant for ease of use in EDEM.
As the equation predicts a volume of material to be removed, this is rearranged to provide the depth per element.
The input to EDEM
is the wear constant W with units 1/Pa.
Interaction | Configurable Parameters | Position |
Particle to Geometry | Assign a Wear Constant value for each Equipment Material-Particle interaction. Record Relative Wear (On/Off). | Last |
EDEM also allows you to deform Geometry
according to the quantitative results given by the Archard Wear model. To enable
this feature, select Enable Deformation in the parameter
values.
