The Linear Cohesion V2 contact model is an enhancement of the Linear Cohesion model
and was made accessible for the first time in EDEM version
2017.2) owing to its improved performance for non-uniform particle size
distributions.
Similar to the Linear Cohesion model, this modifies the Base contact model by adding
a normal cohesion force. This force is described as follows:
Where A is calculated as:
However, in this model, the radius of overlap squared is calculated
as:
Where R1 and R2 are the radii of the particles in contact in
cases where the element 2 is a Geometry.
k is a cohesion energy density with units Jm-3.
This means that, for the same input parameters, the ratio between the forces
calculated with Linear cohesion V2 (FV2) and Linear Cohesion (F) models will be as
follows:
In the case of uniform particle size distribution:
In this case, the cohesive force calculated in the Linear Cohesive V2 model is
therefore four times smaller than the one calculated in the Linear Cohesive model
(for a uniform particle size distribution).
In cases where element 2 is a Geometry, the force is two times smaller as follows:
| Interaction |
Configurable Parameters |
Position |
| Particle to Particle, Particle to Geometry |
Click the + icon to add cohesion to
particle-particle or particle-geometry interactions. Set the energy
density for each interaction. Energy density is the scaling function
for the cohesiveness of the material. The SI units of energy density
are J/m3. |
Any |
