The Hydrodynamic Lubrication contact model simulates the effect of short-range
hydrodynamic forces on particles as though they were saturated in a fluid.
The model integrates the work of three studies (see References and
Bibliography), resulting in a model that may be used for both
Particle-Particle and Particle-Geometry contacts, with the assumption that the system is
fully saturated, and no fluid free-surface is involved.
The model was developed to
capture important macro-mechanical phenomena, such as strain-rate dependency and
shear thickening, in dense granular suspensions, under shear and extensional flow.
One of the key underlying assumptions for a dense suspension is that the particular
volume fraction is high (φ > 0.45), which naturally leads to narrow gaps between the
particles. This leads to a further assumption that the fluid flow in these gaps is
laminar, meaning the model is most applicable in low-inertia systems and not in
systems with turbulent fluid.
The model is a purely viscous model and is not
applicable to static conditions. This model has been used to simulate shear and
extensional flow in granular dense suspensions, though it may have a wider
applicability.
Note: This model does not explicitly model
the fluid, but its impact on particle behavior.
Calculating Particle-Particle Force and Torque
For particle-particle contacts, the model uses the theory as outlined in the work of
Cheal &
Ness (2018). In Figure 1, for two particles p1 and
p2 with linear velocities U1 and U2, rotating
at angular velocities Ω1 and Ω2, with center-center vector d,
pointing from p2 to p1, with corresponding unit normal
n=d/|d|, the force F and torque Γ acting on p1 are defined as:
where ⊗ is the outer product, μ is the viscosity of the fluid, and the remaining
coefficients are defined as:
where
As mentioned in Cheal & Ness (2018) , the model is only intended to capture ‘short
range contributions’. Therefore, interactions are only considered for an additional
hydrodynamic force if they satisfy the following outer cutoff condition:
where rmin is the smallest of the two particle radii:
In addition to this condition, an additional inner cutoff condition is imposed so
that the lubrication forces and torques are calculated down to a minimum separation
distance of hinner rmin.
For contacts that have h < hinner rmin, the following is
applied:
This means that hydrodynamic forces and torques are only calculated in the range:
But, these forces and torques are applied for all
The default values are hinner = 0.001 and hinner = 0.05. This
additional condition, and default values, are employed based on the approach of
Cabiscol et
al. (2021) , where the value of hinner = 0.001 was selected to
reflect the asphericity/roughness of the beads used in their experiments. This inner
cutoff value should be adjusted according to the surface roughness of the material
being modeled.
Calculate Particle-Geometry Force and Torque
The works of two sets of authors are used for resolving Particle-Geometry contacts -
one for calculating the normal force component (Goddard et al.
(2020)) and the other for calculating the tangential force and torque
components (O'Neil
& Stewartson (1967)). All Particle-Geometry contact models follow the
same cutoff implementation as the Particle-Particle model, using the approach of
Cheal &
Ness (2018) .
Normal Force
There are two possible approaches for
the calculation of the normal force, both outlined in Goddard et al.
(2020). One follows an analytical approach, henceforth referred to as
Goddardlog, and the other follows a numerical approach,
henceforth referred to as Goddardsum.
For
Goddardlog, following the approach of Goddard et al. (2020), for a
particle of radius r1 approaching a Geometry element with an assumed
radius r2, that is very large, the ratio of their radii is defined
as:
The gap between the particle and Geometry is termed ε, which is
non-dimensionalized by the particle radius as shown in the following
figure.
The non-dimensional normal force on the particle as it approaches
the Geometry in the normal direction is then defined as:
where higher order terms have been ignored. K2 has been calculated
as described in equation (B21) in the Appendix of Goddard et al in References and
Bibliography. As the calculation is complex, steps for calculation
are omitted here. See the original paper for its calculation.
Considering
that the radius of the Geometry element is assumed to be quite large, the
resulting force experienced by the particle after re-dimensionalization with the
typical drag scale 6πμUr1 is defined as:
where 2U is the relative approach velocity between the particle and Geometry
and μ is the fluid viscosity.Using the definitions of ε, r1, r2, U, and μ as
mentioned above, for the approach of Goddardsum, also outlined in
Goddard et
al. (2020), the dimensional normal force on the particle as it
approaches the Geometry in the normal direction is calculated by:
where c > 0 is a geometrical constant, defined as follows, and an,
bn, cn, dn (η) are series coefficients,
dependent upon η, defined as follows. The complete definition of these series
coefficients are omitted for brevity though they are defined in Goddard et al.
(2020). An equal and opposing force is applied to the
Geometry.
The approach of Goddardsum uses spherical bipolar
coordinates (η, ξ, θ) to represent both particle and Geometry as constant values
of η, which conveniently represents two non-intersecting coaxial spheres, with
centers in the Cartesian plane at (0, c coth(η)), and radii c | csch(η)|.
Designating the distance from the center to center of element i to the origin O
(taken to be the contact point) by di and its radius to be
ri, the spherical bipolar ordinates that define the particle
(element 1) and Geometry (element 2) are as follows:
Figure 3 provides a visual representation of this definition, which is not
commonly used in DEM. For more information about the approach, see Goddard et al.
(2020).
Tangential Force and Torque
Following the approach
of O’Neil
& Stewartson (1967), consider the scenario of a particle of
radius r moving parallel to a Geometry. The non-dimensional gap between the
particle and Geometry is termed ε, as outlined previously and shown in the
following figure.
The tangential force exerted on the particle is then
defined as:
where
and the higher order terms in ε have been
ignored. An equal and opposite force is applied to the Geometry.
The
torque applied is defined as:
where, for the particle:
and for the Geometry:
The higher order terms in ε have been
ignored.
Cutoffs
The inner and outer cutoffs explained
previously for Particle-Particle contacts (and in Cabiscol et al.
(2021) ) are also utilized for Particle-Geometry interactions, which
means that the forces and torques outlined as follows are only ever calculated
in the range:
but are applied for all where hinner, houter, and rmin are as
described previously.
Using the Hydrodynamic Lubrication Model
To use the Hydrodynamic Lubrication contact model, you must first add it to the
Physics of a given EDEM simulation and then configure as
required.
The model will run without a contact radius specified for the particles, but to
capture the full range of forces, you must specify a contact radius that will cover
separations up to the specified outer cutoff . This means that the contact radius
should be at least half of the outer cutoff distance on top of the physical radius.
For example, with the default outer cutoff defined at 0.05 rmin , the
contact radius should be at least 1.025 rmin , so that when two contact
radii just touch, the center-to-center distance of the particles is 2.05
rmin. and hence the gap between the particles is 0.05
rmin.
Also, while you can enable the model while using polyhedral particles which currently
do not have a contact radius, the full range of forces will not be applied
correctly. You must proceed with caution when you want to use polyhedral particles
with the model.
In the Creator Tree, select Physics.
Select Particle to Particle and/or
Particle to Geometry from the
Interaction dropdown list.
Click Edit Contact Chain at the lower section of the
Physics panel.
Under Plug-in Models, select the
HydrodynamicLubrication checkbox.
Click OK.
The plug-in is displayed in the Model
panel.
Select the plug-in and click the icon in
the lower-right section of the Physics panel to configure it.
In the Hydrodynamic Lubrication Model Parameter
Editor dialog box, specify values for Fluid
Viscosity, Inner Cutoff, and
Outer Cutoff.
Note: Because one of the assumptions for the
theory is that the particles are fully saturated with fluid, these
values are applied to all particles in the simulation, rather than by
type or interaction. As noted by Cabiscol
et al, due to the omission of long-range fluid effects in the
model, using the real fluid viscosity may not yield the same behavior as
in the real-world. It has the same units and plays the same role as the
real fluid viscosity, but it is recommended to perform a calibration on
the fluid viscosity (as well as inner and outer cutoff values) to obtain
the correct material behavior.
Select the additional checkbox for the Particle-Geometry contact model to
allow selecting the Goddardlog implementation for normal force.
The most recommended default implementation is that of
Goddardsum. You can select Goddardlog only if
a simulation is already using the Hydrodynamic Lubrication model from
EDEM v 2023.1, which only had the
Goddardlog implementation, and to ensure
consistency.
After specifying the values, click OK.
Post Processing
Lubrication forces and torques are directly added to the particle characteristics
Total Force and Total Torque. As a result, they are difficult to analyze separately
from other contact forces and torques.
