Release Notes EDEM 2025.1.1
This section contains information about the EDEM 2025.1.1 release, such as bug fixes.
Bug Fixes
This section lists the fixes for issues in EDEM version 2025.1.1.
EDEM version 2025.1.1 contains fixes for the following issues:
  • Third-party applications which are dependent on the EDEM Coupling Interface were failing because a number of libraries were not available in the correct location.
  • With some non-English language packs installed, EDEM was not accepting values if the decimal separator used was a comma.
  • The search function within the EDEMpy documentation was not working as expected and returning inaccurate results.
